e30 N3 with e36 M3 front suspension swap.
  • dbenson
    • Jan 2017
    • 25
    Board,
    I know this subject has come up a lot and in all my reading it seems what I have done is correct but the outcome is not what I expected.
    I have KW e36 M Coils, e30 Camber plates, Z3M Spindels and LCAs installed but my wheels are still thrusted toward the rear of the car. I have checked all my part numbers and from my reading they care correct. Are the Z3M LCAs not the same as the 96+ e36 M3s? This is the only thing I can think of that could be wrong.
    Any insight?
    Thanks a mill for the time.
    88 e30m3 S50B32
    93 e34m5
    08 e61 535xi done up
    17 f15m
  • mtech325
    • May 2008
    • 569
    The Z3M shares the same control arms as the 96-99 M3, so you should have the correct parts. Even with use of the offset control arm bushings, the e36 M3 5-lug doesn't seem to achieve the same wheel placement as the e30 stock suspension when compared side by side (both e30 4-lug and e30 M3 5-lug).
    Some people go as far as to use aftermarket adjustable control arms, or custom control arm bushings to add even more caster, but the e36 5-lug can be tricky to setup.
    • MuhTorks
      • Jul 2017
      • 28
      Treehouse-style control arm mounts should give you the additional caster needed to center your wheels
      • bimmer630
        • 1230
        He doesnt even mention what CAB hes using
        • E30SPDFRK
          • 5715
          e30 M3's have the front wheel opening pushed forward compared to regular e30's as well, so what centers a wheel on a regular e30 won't work as well on an m3. I've had to use the 96+ e36 arms on an m3 with just lowered suspension to prevent rubbing with larger tires.
          Byron
          Leichtbau
