while racing the other day, I went airborne and when I came down I blew out the inboard CV joint of my driver side. I made the 5 lug swap a few years ago and I can't remember what axles I used. I ordered a 318ti axle on amazon, but when it arrived it was about an inch too long. fortunately, I was able to take the CV joint off and replaced the damaged CV joint with it so I am back running. Is there a post somewhere that compares axle lengths and flange bolt patterns. I need to figure out what axles I have.
318ti axle question
As I said, I can't remember what I did when I put this together. It looks like I am using 318ti axles in order to have the abs work, but they are matched to the medium differential that I have, so I must have changed the outputs of the differential to the smaller ones from the small differential. I was able to go to a pick n pull and get axles from a 95 318ti that worked.Richard
