Verify my proposed 5 lug setup before I purchase!
  • fastestbox
    • Jul 2018
    • 124
    Apologies if something similar has been discussed, but I searched and read most of the major 5 lug threads with not an entirely clear and solid answer to my question.
    I'm currently running e38 style 5s on 18mm adapters, and I want to ditch the adapters so I feel like 5 lug is the way to go. Yes, buying 4x100 wheels might be cheaper, but I do like the idea of upgrading my brake system while I'm at it.
    Anyways, here's the list I'm thinking of:
    For the rear-
    SRS Concept rear caliper adapters
    eBay link
    Z4 hubs (33416752381)
    E46 328 (or 330) Rear Calipers
    E46 328 (or 330) Rear Rotors
    For the front-
    Max399 5 lug front kit
    eBay link
    E46 328 (or 330) Front Calipers
    E46 328 (or 330) Front Rotors
    E46/E36 front hubs
    Am I missing anything? I don't want to start acquiring parts and then ending up missing a bunch before I get started.
    Through eBay and some other sources I've calculated the total to being around 700~
    Thanks guys!
    91 318iS - aluminum M52B28 + ZF320 + 3.15 Torsen
  • Metallated
    • Dec 2016
    • 1073
    Looks like everything to me. I guess I'd just be a little skeptical of the ebay parts. Brakes aren't really something you should cheap out on lol
    Do you know anyone using these?
    • fastestbox
      • Jul 2018
      • 124
      That's good to hear! The Max399 hub adapters have a good amount of users on r3v, I believe Max399 himself was selling them here for a while.
      The SRS Concept adapters are a bit less common, but it's just a usual caliper adapter setup people have been using for years.
      • LowR3V'in
        • 4209
        ya looks good all u need is brake lines.
        the rotors and calipers are ultra heavy compared to the stock ones though.
        might feel it with that 4 banger maybe.
        Also, do not.. do nooot get generic ebay hubs.
        spend like 20 bux extra and get the febi ones at least, if not, oem.
        check out my post about it.
        • fastestbox
          • Jul 2018
          • 124
          Which lines should I get? Was it e30 fronts for the rear and e36 for the front right?
          I definitely won't be getting the eBay hubs now!
          • LowR3V'in
            • 4209
            whatever the kit says to use.
            i'm using the e46 m3 fronts so that line works and e39 rears so the e30 front lines work for that.
            • AndrewBird
              The Mad Scientist
              • 11898
              How are you using Z4 hubs in the rear? Are these a direct swap for the stock hubs? I thought you had to go to E36 318ti trailing arms to convert?
              • fastestbox
                • Jul 2018
                • 124
                I'll look more into it, thanks for you help!
                Yeah! They apparently bolt right on. You will need a caliper adapter to actually run a compatible brake system however. Also it's a bigger wheel bearing setup than the E36 Ti so take that how you will.
                • LowR3V'in
                  • 4209
                  how flush is your current setup?
                  the kit puts 17x8 et20 in the hella flush category but i assume ur all roll flushed out.
                  Enjoying the e30 by jet jones, on Flickr
                  • fastestbox
                    • Jul 2018
                    • 124
                    I can definitely get down with it being flush, my current setup is pretty flush but the front wheels stick out a tad more than I want them to, and I'd imagine the 5 lug swap would help me out with that.
                    I used to autocross an e90 335i and I'm itching to get back into it with the e30 and I'd love to be able to run a little thicker tire once new tire season comes around
                    • fastestbox
                      • Jul 2018
                      • 124
                      Pulled the trigger on the Max399 fronts and SRS Concept rear, going to casually look around the local junkyard for calipers/caliper brackets that I can rebuild while I wait for the economy shipping from Lithuania.
                      What's the brake line situation on these? I've scoured the internet for answers with this setup and I can't find any perfect answers. I've heard stock e30 will work?
                      • alistairolsen
                        • Jul 2017
                        • 191
                        please post some details and pics when you install them, I'm looking to go the same direction. Thanks
                        • N/A
                          • Sep 2019
                          • 77
                          Reviving here. How’d this go??? Looking to do a similar setup... Sent from my iPhone using Tapatalk
