question?
  • BahnE30
    • 1050
    question?
    can i just press E30 M3 hubs on to my non M trailing arms, and use my non M halfshafts, or do i need to find M halfshafts?
    also, for the front all i need is strut tubes, rotors, calipers, and the hub / bearing assembly from an E30 M3?
  • Van Westervelt
    • 9365
    for the front, you will also want the sway bar end links.
    • BahnE30
      • 1050
      but i can get by for now just running the non M end links?
      also on the bottom of the strut, there doesn't seem to be any place to attach the ball joint and tie rod, is a piece tha tbolts to the strut to allow this? i notcied in a picture of Jordans set up, he has a spacer between the strut and this piece, is this nessecery.
      • Van Westervelt
        • 9365
        I dont beleive the spacer is necassary, but you do need that knuckle that connects the ball jounts to the strut tube. The end links are optional.
        • BahnE30
          • 1050
          okie dokie, thanks for the help dude.
