Which swaybar links to use on swapped cars?
  • clavinZERO
    Hella sick E30
    • Mar 2004
    • 2027
    which style links fit best for the e36M3 front suspension swap? From what I understand, keeping the swaybars parallel to the control arms (keeping the joints all about 90 degrees) is optimal.
    stock e30 (non-M) style to the control arms
    or
    e30M3 links (long ones) to the struts
    or
    e36M3 links (long ones) to the struts
    "BMW Style 32 Poster-Child"
    HTTP://WWW.CLAVINZERO.COM/e30-5-lug
    **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
  • PiercedE30
    • Apr 2005
    • 4220
    well, if your using E36M3 units, and either coil overs or just springs, get some adjustable E36M3 style ones.
    My 2.9L Build!
    • clavinZERO
      Hella sick E30
      • Mar 2004
      • 2027
      someone else recommended that to me as well. I have e30 bars and e36 struts. I'll take a look to see what I can get. Any more input from anyone who has done the swap would be much appreciated.
      • e30devo
        • Aug 2005
        • 1102
        dont the e36 control arms have the hole for the mounting of a sway bar e30 style? i was thinking about this aswell and was just gonna bolt it where it would go on an e30...
        • clavinZERO
          Hella sick E30
          • Mar 2004
          • 2027
          ANSWER: the e30 bars DO bolt up to the later e36 control arms in front, no problem. It's how I did it on my swap. Way to answer your own shit, eh?
          • chuck90m3
            • 568
            since you are using the M3 struts, i think you will find that using either the M3 E30 or M3 E36 swaybar link will provide you with better performance. dont ask me why but i would assume that BMW Motorsport did this for a reason. the links are cheap i say swap them out and find out, but as i said i think the later versions will work better.
            "A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
            Friedrich Nietzsche
            • clavinZERO
              Hella sick E30
              • Mar 2004
              • 2027
              I might switch them out soon (the stock E30 ones for the adjustable E30/E36 M3 style)... the ones I am using have some miles on them and I guess it wouldn't cost too much.
              • chuck90m3
                • 568
                i have a feeling you will like them better. let us know when you do and what you think about the difference
                Friedrich Nietzsche
                • clavinZERO
                  Hella sick E30
                  • Mar 2004
                  • 2027
                  Will do.
                  Also, I have searched some, and have found a few answers, but... can I get some links (if anyone has some) to some vendors for these style adjustable links? I am looking for ones with heim joints so the rotation of the strut is handled better. Any help is appreciated as usual. Thanks!
                    • 37833
                    IE has the adjustable E30 M3 links for $85 retail. I plan on using them for mine.
                    Grover Beach, California
                    BimmerHeads.com
                    • Mossman
                      • Apr 2006
                      • 1961
                      The adjustable ones are good to eliminate preload, that's the purpose correct? I believe that using the m3 style links to the strut increase the effective rate of the sway bar, correct? If you want a stiffer sway up front then it'd be a good idea and the cheapest way to accomplish this, but if your car is neutral or understeers then it might be counter productive.
