So i have the e36 M3/318Ti 5-lug pretty much calculated and in order to keep the costs real low i was wondering if i could cut/modify e36 front strut casings, like i did with my e30 struts, and simply swap my e30 koni shocks and coilovers.
The question is, which e36 strut will take e30 shocks as far as inner diameter goes? and if so what about the coilover sleeve? In the case of the shock the same e30 strut mod will apply: cut/weld + inner spacer. And in the case of the sleeve, i have cosmo coilovers and the sleeve is actually a bit wider than the e30 strut. I surface welded on the casing so that it would fit snuggly and its held soundless for over a year of track.
Anyways i'd love for this to happen as it would mean a 5-lug swap with susepension from my current e30 (may it RIP) all under $500 (junkyard parts and no rims inc).
has it been done before?
