there was a 318ti at the scrap yard today, so naturally i got the trailing arm assembly. i also got the solid part of the brake lines, cut them at the rubber. i also kept some of the ebrake cable, just used bolt cutters. also kept what i believe are the pad sensors? or abs wires? with extra long pigtails. basically, what is required to use them on my car? i think i remember reading that i can reuse my suspension. but how should i hook up the brakes, ebrake, sensors, and abs stuff? does the 318ti even have abs? thanks, im looking forward to using some 16x8 e38 weaves in the rear :up: hopefully the staggered look (4lug weaves in front) wont be too bad, guess i gotta decide if i want a 4 or 5 lug spare haha.
just bought 318ti stuff
Originally posted by lifeiskaos View Postthere was a 318ti at the scrap yard today, so naturally i got the trailing arm assembly. i also got the solid part of the brake lines, cut them at the rubber. i also kept some of the ebrake cable, just used bolt cutters. also kept what i believe are the pad sensors? or abs wires? with extra long pigtails. basically, what is required to use them on my car? i think i remember reading that i can reuse my suspension. but how should i hook up the brakes, ebrake, sensors, and abs stuff? does the 318ti even have abs? thanks, im looking forward to using some 16x8 e38 weaves in the rear :up: hopefully the staggered look (4lug weaves in front) wont be too bad, guess i gotta decide if i want a 4 or 5 lug spare haha.
Why not be non ghetto and just do it all. If your gonna spend the time and energy just do it the right way... BTW if I remember right the e38 weaves will stick way out because of offset. They work great on the e30m3 5 lug setups, but that's because you keep the e30 offset. With the 318ti setup, your now going to have to have the e36 wheel or offset, which is around 40 rather than 20 for the e30's.
Originally posted by lifeiskaos View Postit looks fine on piecede30's car... i'll eventually do it all guys, this just became available so i figured i'd buy it. who cares if i have different lug patterns for a while? i'll put the hub caps on, no one will know lol
Just put them on and have fun with your new 5-lug setup. use the E30 ebrake cable and everything else from the ti.
Originally posted by 2002maniac View Posthe has E30M3 parts in the back. you'll have to use e36 offset wheels.
