318ti rear coilover setup.
  • loonibab325i
    • Dec 2005
    • 770
    So what route did everybody go for the rear? I have my front all setup i'm using the m3 front suspension including m3 groundcontrol coilovers... but for the rears i'm using 318ti rear trailing arms and ground control wont sell me the damn perches separately so what are you guys running?
    -Abe.
    s52 0-150mph & more http://www.youtube.com/loonibab325i
  • twistednut
    • Nov 2007
    • 272
    Is this what you are looking for?http://www.tcklineracing.com/monoball.htm
    Rear Ride Height Adjustors - Exclusive TC Kline Racing designed suspension height adjustment. Lower your car for the track. Raise it back up for street use. These adjustors are made from high tensile aluminum and have a special hard anodizing to ensure strength and durability
    Part Number Description List TCKR
    TCKRSA3 E46, E36, E30 all Rear Spring Ride Height Adjuster (pair) $228.00 $129.00 Order
    TCKRSAZ3 M Coupe/Roadster, Z3 all. Rear Spring Ride Height Adjustor (pair) $228.00 $129.00 Order
    TCKRSAZ4 Z4 all Rear Spring Ride Height Adjuster (pair) $228.00 $129.00 Order
    And then use these for the upper spring seat.
    http://store.nexternal.com/shared/St...t=products.asp
    Spring Pads - Rear for small diameter springs
    e30springpad $12.00
    Add to Cart
    New Product- These are urthane rear spring pads for 2 1/4" to 2 1/2" ID springs. These locate the springs properly when using the smaller diameter racing springs. Priced each. You would normally need 4 per car.
    I think TC Klein's rear springs are designed to be used on an e36 because they do not tuck the tire very much on the e30 when you use the adjusters with them and they are adjusted all the way down.
    what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
    • loonibab325i
      • Dec 2005
      • 770
      WOW, that was exactly what i'm looking for.
      Thanks a bunch!
      -Abe.
