So when I put E36 control arms on... (sway mounts)
  • lukasbmw
    • 651
    When I put some 96+ E36 M3 control arms on my car to center the front wheels, what am I going to do with my front sway bar?
    On E30's, the front sway mounts to the control arms. On the E36, they go to the struts. This means the E36 arms won't have sway mounts.
    I guess I could have the shop (That's right, I'm taking the car to a shop...I'm sick of fucking wrenches) weld the E30 tabs to the E36 arms.
    What have you guys done
    I'd rather not spend the money on new sway bars as I am really trying to be done with mods.
    I'm centering the wheels, ordering some new rims, replacing my gauges, installing Jordan's headliner, and then I'm done done done.
    2004 SL600 - Current
    2006 SL55 AMG - Sold
    2004 M3 SMG - Sold
    1999 540i Sport - Sold :(
    1989 325i coupe- Sold
    1988 325is M50 M-tec - Sold :(
  • Streetspec_iS
    • 1622
    Re: So when I put E36 control arms on... (sway mounts)
    uh huh ... suuure. although, i guess theres not much left to do to your ride.
    good luck with the CAs
    sigpicM42 Brigade ... Throwing craze in the 318
    • DSchultz325e
      • Aug 2004
      • 1158
      he can do a roof chop. POWNED.
      I retired my E30 for now...
      E46 323i
      David Schultz
      • rs4pro3
        • 5808
        Call ground control and order e30 m3 style tabs, they weld to the side of the strut housing and you use e30 m3 links to mount them to the sway bar. Both tabs cost me $24
        85 325e 2.7 ITB'd stroker
        • trent
          done.
          No, they still have a hole there -- will bolt up just the same
          • E30-323ti
            • 328
            Don't worry lukas they do have the holes to put the E30 sway links onto!!
            292rwhp E30 :D
            • lukasbmw
              • 651
              That is good news. Thanks guys.
              2004 M3 SMG - Sold
              • Z3Jonathan
                • 289
                I personally would not weld on an aluminum control arm.
                • trent
                  If done correctly by an experienced welder it is not a problem. On the other hand...
                  • E30-323ti
                    • 328
                    LOL, Trent must have got in like 2mS before me on that one!!
                    292rwhp E30 :D
                    • Jay Stock E30
                      • 154
                      (That's right, I'm taking the car to a shop...I'm sick of fucking wrenches) .
                      wimp ;)
                      jk man, like the others said they will just bolt up worse case just drill a hole in the control arm and bolt the tap up, just like the e30.
                      the 98 m3 offset control arms didn't really help my car out ahole lot, I guess I'll be trying camber/caster mounts next...
                      • trent
                        Me:
                        Posted: Sat Sep 04, 2004 6:49 am
                        You:
                        Posted: Sat Sep 04, 2004 1:59 pm
                        Thats a little more than 2ms? :P
                        • kylebes1
                          • May 2004
                          • 2804
                          I know everyone loves the search tool on here, but Lukas will you do a final run down of the parts you have used? You know just when you are finished and feeling generous.
                          And anyone else that has a centered wheel and five lug since I am sure there are many was to do it.
                          Also did anyone decide if the Treehouse bushings are any good?
                          • bmw4aaron
                            • May 2004
                            • 32
                            The holes are still there.
                            Bolt on an go
                            88 524td/5
                            98 540i/6
                            04 325xi
                            03 MB G500
                            93 Dodge D350 CTD
                            • Jay Stock E30
                              • 154
                              didn't fix the caster on the e36 swap, haven't driven the car yet to see how they feel though.
