what's the smallest rim size that I can use with the E36 M3 brake disks (325mm/20mm width) and calipers on a E30? I wanted the smallest unsuprug weight I could have.
e36 M3 315mm brake discs and rim sizes on E30
Smallest would be 16", and only if it has the proper shape to clear the calipers. Most likely you will need 17" wheels.
LeeBrake harder. Go faster. No shit.
massivebrakes.com
BBS RS's will clear in 16" fitments. But those brakes are why I have a wide array of 17s now.sigpicComment
I have doubts about that. Back in 1995, owners of e36 M3s had a very hard time getting 16" winter wheels as most didn't fit the calipers. The BBS RS is even worst than most wheels because the nuts that fasten the three pieces together portrude in the back, and the rear of the spokes don't offer much room.
Show me an e36 M3 with 16" BBS RS wheels and correct e36 offset, and I will apologize for being wrong.Brake harder. Go faster. No shit.
massivebrakes.com
I rolled my 211's (16x8 ) with my e36 brakes on the back for a little over a month earlier this year.sigpicComment
massivebrakes.com
Lee, I am talking on basis and subject at hand. I am running e30 m3 susp front and rear, in the front I occasionally run the rotor spacer and yes, e36 m3 rotors and calipers as listed in the OP.
Why would we be discussing rear brakes when it is clearly the front in question? 315mmsigpicComment
it took me a while before i collected a set of wheels that would fit over the m3 brakes so i could do the swap on my car, i tried many factory 16"s and several 17"s that didn't fit over the calipers so don't jump on a set of anything that is not known for sure to fit a e36 m3, milli miegla (i know its not spelled that way) use to make a pretty decent quality 16" copy of a m-contour that tire rack sold as m3 winter wheels but they have been out of production for a few years now, i have had my hands on a set (on a customers car) and they seem to be decent so if a set could be found that would be a optionComment
- E34 M5 (x 2) -
- E30 V8 Cabrio "Kylpyamme" -
- Alpina D10 Touring #33/94 -
- E46 318i Touring -
- Toyota Hiace 4wd -Comment
