I trying to find out where the it would plug runs to. I know the e30 abs pulse sensor won't work because it's to long. I haven't tested the ti one yet but was wondering where I would disconnect the stock e30 one at from the rear. anyone sorted this out yet? OR should I throw out the ABS crap ???????? comments????? I see some spaced them but doesn't work to great.
ABS - what to use for 318ti setup?
Tags: None
it won't plug in. E30 connections are under your rear seat. E30 ABS sensor is on 2 wires, and e36/ti have 3. It's in a way a dual sensor, as it has 2 magnetic prongs.
Either way, the best way is to make a spacer for e30 sensor and plug it in. E30 sensor is longer than e36 one, but e36 trailing arm is shaved down to accommodate for that smaller sensor. -
