Originally posted by e30_325es
View Post
Share your 5 lug setup and wheels
This is a sticky topic.
No more e30s for me.
88 black BMW OBDII 332is dedicated track [sold]
88 BMW OBDII bronzit 332is [RIP 03/08]
91 BMW 325i [sold]
86 Corolla 'Ae86' HB 20v trd [sold]
http://youtube.com/watch?v=pTj7Hn9v5Rs
I'd say it works ~80% of the time, the other times it turns the light on. The trailing arms I bought from someone who went a different direction with his e30 (corvette irs), and they came with spacers. I can measure these if you would like. The fronts I cut a slot in the side of the sensor to align them with the trigger wheel. I can get a pic of this if you would like.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
setup: E30 M3
wheels: OZ Racing AC Schnitzer 17x7.5/8.5 ET20/17
kekeke yup.
Rolled, stiffer and lower now.
Originally posted by e30_325es View PostFront:
94325is knuckles and brakes, 97+ ca's, eyeball arms, GC coilovers with Vorschlag camber plates, slotted stock abs sensors.
Rear: 318ti ta's, IE rtab's and sfb's, IE weld in camber/toe adjusters, GC coil overs, TMS shock mounts, spacers for abs sensors.
BBS RKii, 17x8 et38 235/40 Goodyear f1 Asymetric:
Style 32, 15x7 et47, was 195/60 conti's, now painted black with 225/50 Toyo R888:
also you are running non-M knuckles, same as me. It seems like the guys with M-knuckles dont have any wheel positioning problems. I read somewhere that the M knuckles may have some additional built in caster, pushing the axle centerline even more foward than the offset CABs and 97 M-arms will give you (this was just an idea, nobody can seem to confirm it)
I went the full E30 M3 route (see sig) including the steering rack. It's on H&R cabrio spec springs with Bilstein sports. Everyone says it's not low enough, especially in front, and I have to agree. Not sure what I'm going to do about that yet, but I've got other stuff to take care of first.
About the style 5 (E39 or, in my case, E31): The front wheels are ET20, which should fit, but there was minor interference with the calipers, which we shaved a bit with a dremel, but the anti-rattle clips won't play with the wheels. Some guys on s14.net say they wait until the pads are worn halfway then the clips will work. Others use a 5mm spacer, but that pokes the wheel too much leading to fender interference (solve one problem and cause another). I just ordered the new 2mm spacers from ECS tuning. [EDIT: RECEIVED 2MM SPACERS. NOT THICK ENOUGH!] That should be just enough to get the anti-rattle clips on and not cause other problems. The E31 rear wheels are ET26, and apart from slight contact up inside the fender on full compression, they fit just fine.
Originally posted by e30s52 View PostYour first picture is that with the 2mm spacer? and how much did you take off the caliper to fit the wheel on?
95 M3 Spindles
96+ M3 Arms
Fabbed lollipop
Gutted M3 Housings w/ Koni SA
GC Coilover Conversion
Vorshlag Camber plates
318ti hubs and bearings
E36 M3 Brakes
On DS1's w/ 235/40/17 Falken azenisPast Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
Originally posted by Dave McLaren View PostI went the full E30 M3 route (see sig) including the steering rack. It's on H&R cabrio spec springs with Bilstein sports. Everyone says it's not low enough, especially in front, and I have to agree. Not sure what I'm going to do about that yet, but I've got other stuff to take care of first.
wheels are OZ ultraleggeras
setup is:
z3 1.9 springs (H&R)
front - e36 325i shocks / spindles / brakes, '96+ M3 control arms, 17x8 et40 w/ 205/45
rear - z3 1.9 trailing arms / brakes, 17x9 et41 w/ 225/40
now to finish the rest of the car... *sigh*past:
1989 325is (learner shitbox)
1986 325e (turbo dorito)
1991 318ic (5-lug ITB)
1985 323i baur
current:
Originally posted by bimmer630 View Postdo you want to retain the current springs you are running and drop the car a little bit? I work at a dealer and another guy there was messing around seeing what parts would fit on his E30 and it turns out the spring diameter is the same on the new E90 3 series. the top spring plates have a deep "dish" to them, so the strut bearing sits down lower in the coil spring than normal. you would lose strut travel but retain your current springs and be able to lower the car down quite a bit (although we havent tried it yet, so we dont know. he ordered one so maybe i can take a pic of it. the p/n is 31 33 6 764 093
