5 lug swap question
  • fiercee30
    • 199
    5 lug swap question
    i was wondering if i could use an e28 parts my E30 to make it a 5 lug swap ?
    84 ETA
  • Aptyp
    • 6584
    what do you have in mind and why?
    • fiercee30
      • 199
      i want to have more options for wheels and i know that E28 parts are interchangeable so i would like to make a 5 lug swap maybe for some BoRbets Ts
      84 ETA
      • Aptyp
        • 6584
        well, front spindles are completely different... calipers are on the wrong side, and the way everything mounts up is 100% different.
        Rear is whole other world of completely. Hubs are inverted.
        If you want to give this an effort and guinea pig for us, that would be great.
        • atomic
          • Jun 2007
          • 5691
          IIRC only the front e28 hubs/bearings will work on e30 M3 strut assemblies, but you have to change out the ABS rings for them to even work on a e30. They WILL NOT work on standard e30 strut housings...
          Probably better off not trying to reinvent the wheel and do what has been tested and wrote about many times on this site...
          GL
          • fiercee30
            • 199
            well someone told me that i could use e28 housing to convert to 5 lug
            84 ETA
            • Aptyp
              • 6584
              someone hates you
              • m3maker
                • 210
                Originally posted by Aptyp
                someone hates you
                lmao!
                • e30s52
                  • Oct 2007
                  • 5235
                  Does no one search any more?
                  www.gutenparts.com
