Clunk in front end
  • christoble
    • Sep 2005
    • 222
    Clunk in front end
    There is a clunk coming from the front left when i hit a pot hole or a speed bump also when i first release the break after coming to a stop. When i jacked up the car it only made any noise when i tried to move the wheel front to back. I have bilstein struts, h&r springs, k-mac camber kit, bmp cab's and new control arms. any thoughts before i start taking everything apart
    Parts for sale http://www.r3vlimited.com/board/showthread.php?t=128440
    Car for sale http://www.r3vlimited.com/board/showthread.php?t=118679
  • royalflush313
    • Mar 2004
    • 2070
    Did this happen just after you installed those suspension items, or is it a relatively new symptom?
    Maybe upper strut mounts.
    ~ Go Canucks Go! ~
    • christoble
      • Sep 2005
      • 222
      they were installed about 3 years ago about 10000 miles on them. It just started out of know where about 2 days ago.
      • sharkd
        • Apr 2005
        • 82
        Check the caliper mounting bolts -- I was having the similar mystery noises that ended up being the caliper slowly unbolting itself due to insufficient torque. (A bad thing.)
        “one of the most beautiful BMW’s ever...”
        • christoble
          • Sep 2005
          • 222
          when i hit the brakes the wheel shifts backwards about a half an inch or so. im going to look at the caliper tonight and see if the bolts are tight. Also this weekend im putting treehouse cabs on it to see if it makes a difference.
          • christoble
            • Sep 2005
            • 222
            well i put the cabs on today and made sure all the bolts in the breaks were tight, also checked all the bolts on the strut tower and they were fine. The car is still making the clunk but its not as bad. What else could it be?
            • royalflush313
              • Mar 2004
              • 2070
              maybe check your balljoints and swaybar bushings
              ~ Go Canucks Go! ~
              • Brew
                • 3060
                Control arms.
                '91 318is
                • DarkWing6
                  • Apr 2004
                  • 7144
                  Originally posted by Brew
                  Control arms.
                  +1
                  I had the same problem in my car and new control arms fixed it.
                  • SchnellerVert
                    • Sep 2005
                    • 3948
                    Did you tighten the Shock nut sufficently? Up down slop in the strut.
                    • christoble
                      • Sep 2005
                      • 222
                      the control arms are about a year old. The bolt at the top of the strut was a litle loose but i tightend it and it didnt help with the clunk
                      • SchnellerVert
                        • Sep 2005
                        • 3948
                        Tighten it with impact gun to over come the spinning of the strut tube or with hand tools?
                        • royalflush313
                          • Mar 2004
                          • 2070
                          toque spec is only like 50lb/ft for the shock top nut, you don't really need a impact gun, if that's what you are suggesting.
                          ~ Go Canucks Go! ~
                          • christoble
                            • Sep 2005
                            • 222
                            its really tight now and its still clunking.
                            • arsevader
                              • May 2005
                              • 1025
                              You are asking for trouble tightening this with an impact gun. You run the risk of twisting the strut.
                              James
