Hey guys/gals. I'm still pretty noob, but been piecing together a suspension setup for my car, i just want to do 1 day, full install, so i want to know if i am forgetting anything..
here is what i have in shipping, or in my trunk:
IE 22mm sway bar- rear
IE Front Adjustable 22mm sway bar- front
Front Camber Plates
Sparco Front Strut Brace
In my shopping car at IE (tell me if i should add, take out anything):
Rear Shock Mounts (the billet alumn)
Rear Bushing kit (needed for rear sway bar)-Urethane
REar Sway Bar Mount-2 of those
I need suggestions on the shock/strut and spring combo, decided against coilvers, because as well as they handle, they will cost more than i paid for my car, and I could use the money to help pass smog, and fix up the interior a bit.
Well, anything else I may need? As i said, i just want to do a cheap setup that will be good for occasionaly SCCA auto-x, and i want to do it all at once.
I am upgrading my brakes too, well going through IE with front cross drilled, rear OEM replacement, and the Mintex Red Box Pads all around.
Thanks for any input!
-Roy the noob
Front Camber Plates
-Roy the noob
