OFFSET question?
  • europeanplates
    • Jun 2005
    • 1607
    OFFSET question?
    I have a few sets of wheels for sell. I am now wondering what offset is needed for the E30 (non M) the wheels are 16x7 and 35mm off. Will they work or will spacers be needed. I have used the search and came up with all sorts of dirrerent info. Let me know I would like ot see some of these to members but want to make sure they fit. Center bor is 57.1
    Tyler
    http://www.europeanplates.com Build and Preview plates
    R3V Discount Code = R3V2012
  • browntown
    • Jun 2004
    • 3524
    From what I've read, and I think I've read all the posts with offset questions, as a general rule, 7" wheel factory offset I believe is 25mm, so ~10mm spacers.
    • Van Westervelt
      • 9365
      I have the same size rims, same offset. Mine rub a little at full lock on the plastic inside the front part of the wheel well. So I have 8mm spacers. Wasnt ever too much but I would nic it occasionally. So i put on the spacers. Now that I have larger sways, the inside of the tire rubs them on cornering, agh! So maybe 10 mm would solve all the issues :) Even without spacers though, the rubbing is only at full lock.
      • europeanplates
        • Jun 2005
        • 1607
        E30 Gruppie, so you are saying the SSR you have are 35mm off and just rub when corner, is there any tire rub against the strut or elsewhere.
        Tyler
