Thickest front camber plates?
  • StereoInstaller1
    GAS
    • 22679
    Does anyone know who makes the thickest camber plates?
    I want to raise the front of my car 1/2" or a bit more.
    I would like adjustable, but don't really care, as long as I can remove 2 degrees of negative.
    Anyone wanna upgrade NOW?
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
  • BimmerToad
    • Sep 2004
    • 1537
    Get a coilover kit so that you can raise the car from a combination of long spring and threaded perch. Much easier than trying to find a thick camber plate. Generally adjustable camber plates have an overall height lower than the stock strut mount.
    San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
    • matt
      • 3732
      Installing a longer spring or raising the coilover's perch will reduce droop travel on the strut. A spacer seems like a good idea to me.
      • StereoInstaller1
        GAS
        • 22679
        Guys, thank for the suggestions, but I really like the feel of my combo...I just want to raise the front a tiny bit AND pull some camber back.
        Luke
        Closing SOON!
        • Beej '86 325es
          • 2639
          The Kmac adjustable camber mounts are probably about as thick as you'll find, but I think they're about as thick as the stock mounts.
          -Brandon
          '86 325es S50
          '12 VW GTI Autobahn DSG
          '03 540i M-Sport (sold)
          '08 Jeep SRT-8 (sold)
          For sale:
          S50 TMS chip for Schricks
          • StereoInstaller1
            GAS
            • 22679
            So they don't just go on top of the stock mounts?
            Sorry for the duh-mb questions.
            Luke
            Closing SOON!
            • Beej '86 325es
              • 2639
              na, it's a totally separate entity. :)
              Check this guy's site out, he's got a comparison between the G-C and Kmac setup stack height...
              http://www.e30m3performance.com/inst...p/GC_susp3.htm
              -Brandon
              '86 325es S50
              For sale:
              • StereoInstaller1
                GAS
                • 22679
                Thanks, man. Looks like the easiest, least expensive way is gonna be the IE plates.
                Luke
                Closing SOON!
                • JRKOUPE
                  • Dec 2004
                  • 3159
                  Luke
                  call TMS, Bimmerworld, IE and RRT////////ask them whos is thickest..I have RRT...@ 1/4".....
                  • Axxe
                    • Aug 2004
                    • 3355
                    You have more than two degrees negative camber WITHOUT adjustable plates? How?
                    Keep it slideways!!
                    • StereoInstaller1
                      GAS
                      • 22679
                      I have no clue. Jordan put in my struts and springs. KYB's on B+G springs.
                      3.25 in the front, over 4 in the back. I want my tires to last longer!
                      Luke
                      Closing SOON!
                      • JRKOUPE
                        • Dec 2004
                        • 3159
                        Luke
                        There is no obvious reason how you have neg 3.25! and over 4 in back!!!!!!
                        ...something is fishy.....I run the max rrt plates and get 3.2!......you should get this checked out........QUICKLY
                        • 2002maniac
                          • 4260
                          heres what you need! IE fixed camber plates go on top of the stock strut mount and will raise your car 1/4"
                          • BimmerToad
                            • Sep 2004
                            • 1537
                            you'll reduce droop travel, but you'll gain compression travel. A spacer is a good idea, if you want a lifted truck ;)
                            either way, it's not a traditional e30 mod
                            Sounds like what you need is the stock crash mounts, mounted for minimum neg. camber
                            • Charlie
                              kid tested, administrator approved
                              • 6686
                              Luke
                              Adjustable or not?
                              My RRT fixed plates are about 3/8 of an inch thick
                              -Charlie
                              Swing wild, brake later, don't apologize.
                              '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                              FYYFF
