hawk hp+
  • SR-E30
    • Jan 2005
    • 9
    hawk hp+
    I just installed some hawk hp+ pads on the rear of my e30 and they are very loose has anyone ever had this problem with these pads? On the orig pads there was a clamp of some sort on the inside pad that inserted into the caliper cylinder is there a way to reinstall this clamp on the new pads?
    Italia
  • SR-E30
    • Jan 2005
    • 9
    help me out guys
    Italia
    • Garageaholic
      Freestyle Fabricator
      • Dec 2005
      • 5204
      Yeah, you need to use that clamp.. it keeps pressure on the pad and the caliper.. Reinstall them, take it for a drive, and then see how loose they are..
      You can also write with magic marker on your rotors, take it for a drive, then see if that mark has worn away. If it has not, then you have a bigger problem on your hands..
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      Instagram.com/garageaholic
      Youtube.com/garageaholic
      • SR-E30
        • Jan 2005
        • 9
        Why Would I Write On The Calipers? The Problem Is In The Pad. I Didnt See A Way To Reinstall The Clips
        Italia
        • Garageaholic
          • Dec 2005
          • 5204
          is the thickness of the pads the same as stock new pads?
          Have you driven with them yet?
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          • SR-E30
            • Jan 2005
            • 9
            Yea They Arte New But I Put About 50 Miles On Them. Now I Have A New Problem I Just Snaped The Caliper Pins Trying To Tighten Them With Air Tools
            Italia
            • Garageaholic
              • Dec 2005
              • 5204
              the 2 caliper bolts? with the allen wrench hookup? ouch. You NEVER tighten stuff with air tools. always loosen with them.
              food for thought, that's all.
              Recent Rebranding!!
              E30 SM62/S62
              E30 M60 V8
              E30 M30 Big 6!
              • SR-E30
                • Jan 2005
                • 9
                Thanks
                Italia
