help please. trouble with tie rods
  • veks
    • Oct 2006
    • 170
    Well I just started with changing springs and stuff. so i went through with the www.bimmerdiy.com/e30 front spring and shock replacement. I get to the removing tie rods part and I'm stuck. The tie rods won't budge. My friend and I have been going at the tie rods with the pickle fork for a long time, and it just won't budge. Can someone give me some advice please?
    Thanks.
  • Brew
    • 3060
    Too bad about the pickle fork... you most likely ruined the boot doing so.
    You want to give the knuckle a hard, sharp whack with a hammer right where the tie rod bolt goes through. Should come right out, if you still have trouble you can try putting a little downward pressure on the tie rod with a prybar while whacking.
    '91 318is
    • MikeE30325i
      • 2356
      basically take time and precisin and hit the tie rod bolt VERY hard. have fun.
      • Brew
        • 3060
        No, do not do that. You will mushroom the stud and fuck up the threads.
        Do it how I said, I do this shit everyday.
        '91 318is
        • 1991 318is
          • Dec 2005
          • 786
          Be sure and leave the nut on. It protects the threads in case the hammer slips. Also, hit from the front to back. If you hit it hard going straight in the impact can go right to the rack and chip a tooth at the pinion. I broken two tie rod removal tools. 1 broke and the other stripped.
          • 1991 318is
            • Dec 2005
            • 786
            Like this?
            [ATTACH]5031[/ATTACH]
            • Brew
              • 3060
              Word.
              '91 318is
              • veks
                • Oct 2006
                • 170
                doesnt this picture show to whack the part that isnt the rod?
                • Dave
                  E30 RAT
                  • 11675
                  Yes, yes it does.
                  Current Cars
                  2014 M235i
                  2009 R56 Cooper S
                  1998 M3
                  1997 M3
                  • veks
                    • Oct 2006
                    • 170
                    Originally posted by DaveCN
                    Yes, yes it does.
                    ok then thanks everyone. i'll give her another try.:D
                    • Maddog
                      • Dec 2006
                      • 117
                      Listen to Brew; shops told me the same thing and works like a charm.
                      • Jean
                        • 18228
                        Any luck on this ? I have a pair of complete tie-rods and would like to know if it's something I could install myself or if I should pay for a shop to do....
                        • jajou318
                          • Jan 2005
                          • 1023
                          True story. Use a block of wood when doing this
                          • Borat
                            • Jan 2005
                            • 494
                            or don't hit the bolt? I think would would absorb a lot of the impact from the hammer, you could be there a while.
                            using the above method that above people have described works fine, the trick is "sharp" hits, your trying to shock it loose, not bash the metal out of shape.
