Why are the my front tires wearing out on just the insides?
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    The rear tires wear evenly, but the front tires wear out only on the inside of the tires. I need to rotate the tires to wear them evenly. I drive around 75-80 on the highway on my car, '87 325e. Why are just the inners of the front wheels wearing out? tire pressure? camber? bad bushing?
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
  • kencopperwheat
    King of Kegstands
    • 14396
    How low is your car? Negative camber is probably the culprit.
    Originally posted by Gruelius
    • V8KILA
      • Mar 2007
      • 1
      i am an expert in the tire industry. its what i do. the most likely thing is like the other gentleman said negative camber. some keys reasons that this happens is lack of a quality alignment to make sure your camber is in spec. if the car is lowered then that alters your camber angles. it might not be possable to get it back to spec with out a camber kit. let me know how the car is set up or if it is stock and i could tell you more. ALLEN
      • Garageaholic
        • Dec 2005
        • 5204
        Hey, I have all stock suspension. The car could use an alignment, so that could be a culprit, but there is no alignment for camber, just toe in/out. right?
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
        • Brew
          • 3060
          You have too much toe out on the front.
          Have the car aligned properly, and rotate the tires.
          '91 318is
          • backtrail69
            • Jul 2005
            • 4471
            I have that same problem on my eta...But I am pretty sure I'm running 2-3 degrees neg camber with K-Mac plates (still don't understand how they work)... I need to take a look at the alignment sheets that the car came with, as it was aligned at a performance shop.
            :: PNW Crew ::
            '87 325 4dr, '74 2002
            • Joe318is
              • Sep 2005
              • 6451
              bingo
              Originally posted by vlad
              • joshh
                • Aug 2004
                • 6195
                Toe eats tires faster than camber angle for angle.
                Alignments tend to "wander" over time. Every 6 months at least.
                "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
                ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
                • ldsbeaker
                  • Aug 2004
                  • 3098
                  I would actually do it once a year, but I guess it depends on what kind of driving you do, and how much.
                  Slicktop City!
                  • Mystikal
                    Wheel Fitment Expert
                    • 9602
                    Yes, as others said, it's not camber, it's toe. It's actually quite difficult to get the front tires on an E30 to wear with just negative camber, it's almost always a toe issue.
                    • Garageaholic
                      • Dec 2005
                      • 5204
                      Great, thanks alot guys. I didn't think that it could wear with just toe.
                      Recent Rebranding!!
                      E30 SM62/S62
                      E30 M60 V8
                      E30 M30 Big 6!
                      • SchnellerVert
                        • Sep 2005
                        • 3948
                        \___/ Toe Out
                        /___\ Toe In
                        I___I neither.
                        • 1991 318is
                          • Dec 2005
                          • 786
                          Mnemonic device:
                          Worn on the inside-toed out.
                          Worn on the outside-toed in.
                          Learned it years ago working with stock cars. On solid axles, we corrected the toe after crashes with a torch and a wet rag.
                          Toe will eat up tires a lot faster than camber as previous posters have noted.
                          • M42Technik
                            • 9781
                            Kind of an old thread, but here are the correct toe alignment specs for the 318iS and other stock suspension settings:
                            Front settings: Castor 8½º ± ½, Camber -2/3rdsº ± ½, Toe-in 0.028" ± 0.024, Steering axis inclination 13 5/6thsº ± ½
                            Rear settings: Camber -2º ± ½, Toe-in 0.080" ± 0.031
                            It is my understanding that when aligning, having the car as close to these numbers as possible will result in less wear on inside of the tires. Sadly, mine are shot in the front. I am running -1.5º of camber with my plates though, but when I aligned it a while back, the technician did not put it to these specs. I told him as close to zero as possible basically...
                            Reminiscing...
