e30 M3 Wheel Bearings
  • modifiede30
    • 1208
    Does the M3 wheel bearing work with a non-M3's? I've been thinking about ways of getting to a 5 lug configuration and the front bearings are the entire hub. If this can be replaced with M3 bearings, you're half way there. Anyone tried this?
    Driving is the only way to go faster....
  • UNHCLL
    • 8790
    I *think* they have different diameters...? therefore, they wont fit in a non-m hub
    Below the radar...
    • Bill 84 318i
      • 1600
      Yeah, if I'm not mistaken, the wheel bearings are the same as an e28 and won't swap in.
      • AdamF 88iS
        • 2051
        You got it; for the fronts. For the rears, the bearing is the same; the hub is a seperate piece in the rear.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
