Need suggestions, rear wheel bearings
  • EtaSport
    • 2853
    So 20 year old e30 with somewhere around 450k miles never has its rear wheel bearings replaced as far as I know. Driver's side is making noise, passenger side has play.
    I thought just the drivers side was bad, so I get to work on it tonight (i work at a shop with a lift and good tools). Didnt even get the axle out. It seems to be seized on the hub. Used an air hammer, used a big hammer, used a bigger hammer, didnt budge it. Figured i'd try and get the hub off, used a very large slide hammer. Didnt even flinch.
    About a year ago I had to put an axle in the pass. side, and it took a 4 foot tall hammer and a lot of nerve. I got it out, but there was no way that hub was coming off either.
    Should I take the trailing arms off and send them to a machine shop to get pressed? I dont know if I have any other options.
    Old and improved:
  • SchnellerVert
    • Sep 2005
    • 3948
    You can borrow the tool from school? Doesn't Bimmer Faher from NCC have one or the BFc. tool loaner thread someone has to have one.
    • EtaSport
      • 2853
      done with school now, plus they dont have anything for older cars. Even if i got tools, I thought they were just for pulling the bearing off, not help with the axle or the hub. Last time I used a puller on the hub it started to bend (the hub).
      Im concerned I might break a press trying to get these fuckers out. they are on there.
      Old and improved:
