Another Camber Question.
  • z50_Jumper
    • Apr 2007
    • 1520
    So I just had my LowTec 60/50 kit installed with some Bilstien Sports, the car is awesome however I dont know if i can afford the camber plates yet to straighten them out for street and long trips. Im about to put 1000 miles on the car and am wondering if i should atleast adjust the toe at the alignment shop and weather or not i can install the camber plates later without throwing off the toe alignment.
    Pic for clicks.
  • NC325iC
    • Mar 2004
    • 6565
    camber plates = waste of money for street car
    • z50_Jumper
      • Apr 2007
      • 1520
      I guess i will have to see how much negative camber i have
      • z50_Jumper
        • Apr 2007
        • 1520
        Does anyone know if camber plates after an alignment will throw my toe off?
        • Borat
          • Jan 2005
          • 494
          not in the front but in the rear you should do both the camber and toe kits
          • PaintPro21
            • 660
            adjusting your camber does change your toe yes. for some people thats ok because on the track its ok to run a little positve, but when you want to set a streetable camber setting you want your toe zero'ed out.
            ApexRaceParts.com - Facebook - Twitter
            • Fair!
              • Mar 2007
              • 202
              +1 to this. Luckily on BMWs adjusting to max negative camber at the track will push your toe out slightly. So the easy solution is to run zero toe or a little toe in on the street, then when you go max negative at the track it toes out a tick, which helps turn-in.
              Hater... ;)
              If its a dual purpose street/track or street/auto-x car, adjustable camber plates are a huge improvement in handling. Even spirited street driving can benefit from additional camber in the front of any mcstrut BMW.
              Vorshlag camber/caster plates FTW! 8-)
              Terry Fair - www.vorshlag.com
              Project Thread for the now-burned-to-a-crisp $2011 GRM Challenge Winning E30 V8 :(
