What to buy, how is this replaced? Rear swaybar link rubber?
I noticed that a while ago, while trying to adjust my rear height, and want to know in what kit or what I would buy to replace that. Doesn't look too good.
mine looks exactly the same, its the rear sway bar link bushing, mine is cracked to shit, just like yours, havent got a around to replacing it yet, i dont know if you just replace the bushing, or the whole link. im glad you asked this.
What, an aftermarket set? Stock links will only work with an M3 14.5mm bar and stock 12mm bar, because both have 12mm ends (which is the ID of the rubber of the stock links). Therefore, most aftermarket sets supply a set of their own links (for the rear), but you should call to double check just in case.
Most aftermarket links don't have bushings - they're just heimjointed at both ends.
