ok ive got a 1988 325i convertable automatic 215000 miles need a front end bad im gonna drop the front and put on some srort shocks but what is all the other items you would incuded on a front end rebuild .. its a daliy driver with a nice comute thrue back road twisties ..after the rebuild im going with 16 inch wheels ..thanks for all your advice
front end rebuild ???whats on the list
Tags: None
well if your rebulding your front end.
1. x2 - tie rod ends, they come with both inner and outer. (saftey replacement)
2. x2 - control arm bushings, offset m3's are a good replacement
3. x2 - control arms, with all new ball joints (safety replacement)
4. x2 - sturts, if your going perfomance minded maybe look at bislten
5. x2 - sway bar bushings
6. x2 - sway bar end links
7. x2 - Sturt mounts
thats about all the stuff you can replace in you front end
to upgrade the feel i've listed them in order from most to miniumal
hth
-cam
