First off, last weekend started off as an oil change...
88 325ic
Then I noticed that my CABs were shot (the vibrations i had been feeling when going over some bumps)
Steps I took and made the job easier:
NUMBER ONE: I have a shop press, and air tools...DO NOT ATTEMPT without at least AIR TOOLS
NUMBER TWO: buy replacement nuts for ball joints ahead of time!
I removed the control arm ball joint nuts at the wheel on both sides (easy)
Then i removed the driver side front subframe ball joint nut with a 3 foot ext (1/2 in) a impact swivel and a 22mm deep impact socket, and a 1/2 in husky 600Foot pound impact gun. came off easy.
The passenger side is much more visible but way harder to get to, I didn’t have a 22mm offset box end wrench (would be good for under car removal) so, i removed it from the top. I used a O2 sensor socket that is offset or crowfoot type. This allowed for removal from under the hood instead of under the car, 3/8 to 1/2 adapter, 2 foot 1/2in ext and breaker bar to break then remove the nut.
ON ALL OF THE BALL JOINT NUTS, they wanted to spin while trying to be removed, place jack under car and jack up under the ball joint you are working on (just enough to get the weight of the car on the ball joint) This will keep the ball join from spinning and allow removal.
I then used a 17mm impact socket and impact gun to remove the CAB 2 bolts.
The control arm was free but still stuck, you can fix this in three ways:
First get a hammer and you ext and hammer the posts of the ball joints down (with a partially threaded on nut to avoid thread damage)
Second use a heavy metal hammer and wack the attachment points that the ball joint shafts connect to
Third and easiest, use an air hammer and point chisel to buzz them out from the top. Place the pointed chisel into the divot in the top of the ball joint post and pull the trigger; they will fall right out. (this is why they are pre dimpled)
Thats the ticket!
OK you got them out, but the cabs are stuck on!
remove them in one of 3 ways:
Burn them out with a torch (messy, smoky and dangerous)
Press them out with a shop press (hanging the whole arm by the CAB then pressing on the control arm shaft)
Use a bearing splitter / gear puller tool to remove them
OR
I used the bearing splitter puller, because i had it handy, it was easy!
OK now to reassemble
Get your lollypops or the CAB assemblies with the old CAB still inside, Place it into your shop press or vise so that the lollypop is supported but the outer metal ring of the CAB is not; use a new CAB or a appropriate sized drift to press out the old pieces. Now press in the new CAB paying close attention to the orientation of the Arrow molded in the rubber and the marking on the lollypop.
Do this for both sides paying close attention on how it is to be installed on the car and the correct arrow facing!
OK now to get it on the control arm there are a few ways:
First boil the CAB assembly in hot water and hammer it on with grease or soapy water with the control arm in a vise (hard to do)
Second Using one of the holes in the control arm as a support for pressing; Pass a solid rod through one of the holes in the control arm allowing the rest to hang free beneath the work area of the press, then place the correct side facing up onto the end of the greased control arm shaft, press the CAB assembly onto the control arm via the inner metal ring of the CAB. This will pop on pretty easily now.
Good time to put it back on the car!
Shove the control arm back into position and secure with NEW nuts
********NOTE:: the superseded nut that BMW provides for the front subframe ball joint nut is 21mm not 22mm and it is not nylock style, it is a 21mm fujilock nut*******
NOT ANY MORE!!!!
NEW STYLE!!!!
make sure you have the correct tools!
DO not fully tighten
Wrestle the 17mm bolts back into place for the CAB and tighten down, then put the sway bar nuts back on and tighten down the ball join nuts again USING THE JACK to support the car under the ball joint you are working on. Torque to specs
Let the car sit for at least 2 hours after taking off of jack stands, then drive
300 mi later recheck your torques!
all done! no alignment needed!
Hope this helps
:pimp:
88 325ic
Thats the ticket!
OR
NOT ANY MORE!!!!
NEW STYLE!!!!
Hope this helps
:pimp:
