left front caliper not releasing
  • wodcutr
    • Apr 2009
    • 2193
    What seems to be the problem? If I don't drive my car for a couple of weeks my left front caliper won't release after braking and it starts to smoke after driving a few miles. My question is, is this a caliper problem or a master cylinder problem? The calipers are practically new with only 10k miles or so on them. I have put grease in the guide pins and the the boots are good so there isn't anything that should hold up the caliper from releasing, but I could be wrong. Yesterday when this happened I pulled over to let the brakes cool and after a few minutes I actually heard a pop come from that wheel and the brakes were then released. What do I need to look for to fix this? Thanks!
    The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
  • slo325i
    • 417
    I'm actually having a similar problem as well. Which brake fluid you using?? Dot3 or 4??
    '89 325i - Totaled... good bye my love...
    '87 327i budget stroker - SOLD!!!
    '92 240sx - ca18det powered drift toy - SOLD!!!
    '89 325i - coupe - NEW daily
    '96 Audi A6 Quattro- Grocery getter/baby hauler
    '99 Busa - weekend wheelie monster
    • wodcutr
      • Apr 2009
      • 2193
      I have not replaced any brake fluid since purchasing the car, but the PO had a reputable shop replace the calipers so I would think they would put in Dot4 but I guess you can never be sure.
      • FredK
        • 14761
        It could be a crappy rebuild or a collapsed brake soft line.
        Either DOT3 or DOT4 brake fluid is fine.
        • wodcutr
          • Apr 2009
          • 2193
          The calipers were brand new not rebuilds. How would a collapsed soft line cause this problem?
            This will be:
            A bad caliper
            A bad soft brake line
            A problem with the ABS module
            The last is pretty unlikely and the first to are where to look first.
            • JRKOUPE
              • Dec 2004
              • 3159
              sticky cali
              most likely a bad cali...or just sticky guide pins......remove pins... clean/sand down a bit w/ steel wool..and grease up.
              worked for me.
