I just install new Brembo rotors and Hawk HPS pads last weekend. After I got everything back together, I went out to break in the new set-up. I got up to 30-35 and applied the brakes (moderately) and there was a knocking/tapping sound coming from the front passenger's side of the car. Took the wheel off today to see if I hadn't tightened the caliper all the way or if the wheel/rotor weren't tight enough. Put it all back together and it's still doing it. Under moderate, or heavy, braking I get a tapping/knocking sound. I haven't driven above 30-35 since this started happening for fear that something may go real bad, so I don't know if it does it above those speeds. I'm assuming it will though. Before I changed everything, there was no noise, so I think it's got to be a brake issue, but then again I'm not positive. I can sort of feel the tapping in the floorboards, also. All of my bushings look pretty worn, but again, the car didn't make any noise under braking before the install. I don't want to start swapping parts with the hope that it will fix the problem. Any ideas what this could be?
Noise after brake install
My e30 thread...http://www.r3vlimited.com/board/showthread.php?t=120348Tags: None
The tapping/knocking sound occurs from the time I first apply the brakes, all the way through a full stop. No ideas as to what it could be?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
So I've still got this issue. I went ahead and put in new control arms and M3 CABs, still nothing. I swapped the pads from the passenger's side to the driver's side to see if that was the issue and nothing changed. Any ideas?
ChrisYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
