brake pressure regulator leak..
  • 325dreamer
    • Sep 2005
    • 16
    ive searched but have come up with nil.
    situation: car is eating brake fluid found that it was leaking for the bottom of the BPR
    got a used BPR in good condition but still leaking
    its seeming that i will have to replace the whole metal brake line.
    has anyone ever encountered this problem before? is my diagnosis seemingly correct?
    TIA
    -Zach
    The odds of two brake bias valves leaking are pretty slim. So there a good chance that the failure is in the line. It should be pretty easy to prove or disprove that. throughly clean the valve and surrounding lines and have someone step on the brakes while you watch for fluid leaking.
