Replacing front brake splash guard?
  • raleigh29
    • Apr 2009
    • 93
    How hard is it to replace the splash guard (Item #4 below) on the front brakes?
    Do I need to disconnet the tie rods and control arm ball joint to change it out?
    Any tips would be appreciated. Its knocking against the rotor and making a bad metal to metal sound when I go over bumps.
    03 M3 Vert
    89 325i
  • X_WizarD_X
    • Jul 2005
    • 99
    Don't have to remove any tie rods or control arm parts....You will have to remove the wheel, caliper, rotor and wheel bearing/hub assembly as I don't believe the backing plate will slide over the hub...The plate is bolted to the strut assembly.
    These pics might give you a better idea of the whole procedure:
    The backing plate though should not be rubbing, knocking or anything else unless the bolts are broken...Prehaps you have other issues???
    The Keystone Killers: for the Commonwealth!
    Member #18 of M42Club.com
    1991 318is Diamantschwarz Black
    1992 850i Calypso Red
    • raleigh29
      • Apr 2009
      • 93
      hmmm ok thanks for the advice. I will have to get under there and see if I am missing a bolt.
      03 M3 Vert
      89 325i
      • raleigh29
        • Apr 2009
        • 93
        Well that fix was easy. The 2 bolts holding the splash guard onto the strut had come loose. Applied some threadlocker and tightened them up. No more metal to metal sound!
        03 M3 Vert
        89 325i
