m3 lower control arm bushing
  • manjambles
    • 125
    hey i just purchased them from Brav auto and i just need someone to confirm which way the offset goes.
    ( 0) (0 ) < like that (inward)
    (0 ) ( 0) < or outward
  • Brian D
    • Mar 2006
    • 832
    Like that.
    1973 Bavaria
    • manjambles
      • 125
      wont that create tow and not camber
      • FreedS4
        • 752
        Line up the arrows on the CABs with the dot on the bracket.
        Chris
        • ColdAccord
          • 5926
          i had this inquiry earlier today and received the same answer. hole on the outside for more caster
          Originally posted by blunt
          • wolfgangstbd
            • 960
            Chris
            +1 and (o ) ( o)
            bewbs!
            • bimmer630
              • 1230
              it will affect your toe but the purpose of them is to increase caster. you need to have your toe adjusted back into spec after doing these bushings
              • T Verdier
                • Aug 2007
                • 2636
                Only if your tie rods aren't adjusted Right? I've got them in my car. I'm pretty sure it doesn't effect the camber just caster for more high speed stability
                • eLKuRLy
                  • Oct 2007
                  • 360
                  so, in or out?
                  • chau
                    • Aug 2009
                    • 55
                    Originally posted by eLKuRLy
                    so, in or out?
                    the holes for the control arm would be on the outside.
