Issue installing brand new rotors and brand new pads...
    Finishing up a 5-lug swap. All e30 m3 equip. I rebuilt the calipers on all four corners. When installing the brand new rotors and brakes, the front were an ABSOLUTE BEAR to get on. Just seemed like no matter how much we compressed the piston back into the caliper, there was just not enough space between the pads to accomidate the massive brand new zimmerman rotor and THICK juird pads. Anyone else ever have an issue with this combo of pad/rotor?
    My dad thinks my buddy and I did something wrong or that something isn't right, esp after I told him we had to hammer the back of the caliper to get it on, and that it's so tight we can't rotate either front wheel. I'm beginning to think I may have messed up the front caliper rebuilds, but I dont see how I could have possibly gotten it wrong. There's nothing to it. (Only thing I can possibly think of is that I didnt use any lube like it said to do when I skimmed the directions. The pistons were still wet/slimy from the old brake fluid - not like I stuck them in completely dry though.)
    It just seemed like if we had just one more mm of space it would have slid on snuggly... instead its hammered on SUPER DUPER snug.
    Again, anyone ever have this issue?
    Are you sure you have the right rotors and pads? You should never have to hit it with a hammer. Always use caliper spreaders.
    www.gutenparts.com
      we did use caliper spreaders (for the driver side) and still same thing. I will double check the part number...
        The caliper might be siezed but sence you just rebuilt them that shouldnt be the case. You put them in with the cup side out right? you might have to ethier get new pads or you can take some of the meat off them.
        www.gutenparts.com
          Yea, don't think there is anyway to pit the piston in upside down. Only one end had paint on it and that's the only end with a little lip around the outer edge to for the rubber boot.
          Damn cars, this shit is never straight forward. If its not one thing its another :hitler:
          I'll start by checking part numbers...
            I went through the same bullshit as you when I did my 5-lug. What a piece of shit my car was. I wanted to push it down a cliff.
            www.gutenparts.com
              My issues have been more with the people and companies I've had to deal with along the way. My car has been good to me, at least up until now. We'll see how this pans out. I'd really rather not shave down these pads, I think just running them as is would be better but then I'm afraid the calipers will never work right. Wish I knew more about the issue. Fml.
                running them as is will just cause them to overheat, you need to figure out where you went wrong (either part or installation-wise). As I am sure you understand, brakes aren't the item to run when you know something isn't right.
                '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
                  That's just the reason for this thread, I don't know if something is definitely wrong or if it is just a common issue with this combination rotor/pad when new. if no one lse has had this issue before and the part numbers are right I'm gong to have to assume I f'd up the rebuild and take the fuckin things apart again. Ugh.
                    something sounds way wrong
                    check your numbers
                    then check your specs, rotor thickness, pad thickness, etc
                    were the pistons completely copmpressed before you put pads in, before fluid ?
                    if you rebuilt the capipers, correctly, and have the pistoins completely copmprressed, then either the rotors are wrong or the pads are
                      somethings off. hitting with hammer??!! sounds like incorrect rotors/pads to me.
                      '12 F30 328i Sport Line
                      '91 SpecE30 #523
                      '00 Ford F-350 Dually Tow Vehicle
                      BMWCCA #360858 NASA #
                      128290
                        No way that set up is correct. Check your part numbers, what you ordered against what is shown on the parts themselves. Check your calipers, you may have hosed the rebuild.
                        Sorry for you man, I hate brake jobs period. Doing it twice...UGH!! FTL big time.
                        sigpic 1987 325is
                          Brand new original unlocked Apple Iphone 3G 16GB version....$250
                          We are importer & exporter dealers on all brand new models of Mobile phones with complete accessories in original factory sealed box.They are unlocked to any network.No contract and sim-free they also comes with an additional one year warranty and a six months return policy from our store.
                          Delivery time is 1week,Also we deliver to any location in the world,the minimum order is 1-500unit and we work in 24hours ......
                          buy 3units and get 1unit free of any product you order from us
                          Contact us for more information and ENJOY .
                          LOCATION
                          Company : liberty phone ltd
                          State : washington dc,
                          Country : United States Of America
                          Email:libertyphones_limited@yahoo.com
                          Apple Iphone 3G 8GB ...........$200
                          Apple Iphone 3GS 32GB...........$300
                          BlackBerry Tour 9630.......$300
                          Blackberry storm 9530......$300
                          Blackberry storm 9500......$300
                          Blackberry Gemini 9300.....$250
                          Blackberry Bold 9000.......$200
                          Blackberry javelin.........$200
                          Blackberry curve 8900......$300
                          Blackberry curve 8520.....$300
                          Nokia N95 8gb...................$200
                          Nokia N96 8gb..................$300
                          Nokia N97 32GB..................$350
                          Nokia 5800 Xpress Music.........$200
                          Nokia 5800 Navigation Edition...$300
                          Nokia 6760 slide................$300
                          Nokia 3720 classic..............$250
                          Nokia 6790 Surge................$300
                          SIDEKICK LX...................$220
                          SIDEKICK III..................$200
                          SIDEKICK II ..................$200
                          JUICY COUTURE SIDEKICK I......$200
                          SIDEKICK II MISTER CARTOON....$250
                          JUICY COUTURE SIDEKICK II.....$200
                          SIDEKICK LX 2009.............$250
                          T-Mobile G2 Touch.............$300
                          T-Mobile myTouch 3G...........$300
                          T-Mobile MDA Basic............$300
                          T-Mobile MDA CompactV.........$300
                          T-Mobile MDA VarioV...........$300
                          T-Mobile Dash3G...............$300
                          Samsung i8910..............$300
                          Samsung Omnia i900.........$250
                          Samsung Q1 Ultra...........$250
                          Samsung T559 Comeback......$250
                          Samsung S3100..............$250
                          Samsung A887 Solstice......$300
                          SamsungB7610 OmniaPRO......$300
                          SamsungB7610 Omnia2........$300
                          SamsungT469 Gravity2.......$300
                          Samsung S9110..............$250
                          Samsung A177...............$250
                          Samsung S5600v Blade.......$300
                          HTC G1......................$200
                          HTC Touch 3G................$300
                          HTC TOUCH PRO2..............$300
                          HTC Touch Viva..............$250
                          HTC DIAMOND.................$250
                          HTC Touch Cruise............$250
                          HTC Magic...................$300
                          HTC Snap....................$300
                          HTC Hero....................$300
                          HTC Ozone...................$300
                          XBOX GAMES:
                          Xbox 360 Core System . 200usd
                          Xbox 360 Prenium pack .-220usd
                          Xbox 360 Platinum Bundle Console 240usd
                          NINTENDO WII GAMES:
                          Nintendo DS Lite NDSL Game Console (Pink) .$130
                          Nintendo DS Lite Black (US) .$130
                          Nintendo DS Lite Enamel Navy (HK) . $130
                          Nintendo Wii Game Console (White (Japan Version ) . $160
                          Nintendo Wii (Jap) (Downgrade version) .$160
                          Nintendo Wii Game Console (White (US Version Wii sport included) ..$180
                          PLAYSTATION 3 GAMES:
                          Playstation 3 60GB . $200
                          Playstation 3 80GB . $230
                          Playstation 3 40GB . ... . $180
                          APPLE LAPTOPS
                          Apple Macbook Air..........................$750
                          Apple MacBook (MA700LL/A) Mac Notebook.....$500
                          Apple MacBook Pro (MA611LL/A) Notebook.....$600
                          Apple MacBook (MA254LL/A) Mac Notebook.....$450
                          Apple iBook G3 (M7698LL/A) Mac Notebook....$600
                          Apple MacBook Pro (MA609LL/A) Notebook.....$550
                          Apple MacBook Pro (MA600LLA) Notebook......$500
                          Apple MacBook Pro (MA610LL/A) Notebook.....$600
                          Apple Macbook Pro (885909119400) Notebook..$600
                          And more...
                          We give one free units for every 3 Units been purchased.
                          PROMOTION ;;;;;;from 15th of August to 15th of November
                          Contact us for more information and ENJOY.
                          LOCATION
                          Company : LIBERTY PHONE ltd
                          State : Washington dc,
                          Live chat on Yahoo messenger;;;;;;;; libertyphones_limited@yahoo.com
                            LMFAO isnt it awesome how in the process of upgrading our beloved e30's most of the time we cruse their very existence
                            "God created turbo lag to give V8's a chance" Taylor D.
