so i started on doing the subframe and trailing arm bushings and god lee that job sucks after of 4 hours trying to take of the subframe it finally came of. im a newb in this and let me tell u this is not a job for a newbe ill have pictures up later. by the way i didnt have to remove the parking brake i just drilled thrugh trailing arm bushings.
subframe
Tags: None
I had to drill thrugh the cup where bushings are inserted then but a metal tube in the drilled holes and take the big bolt that holds the subframe insert it back in through the top and wack the hell out of it. i think its the quickest way to get it offsigpicComment
well i didnt want to burn them coz it will burn black and i did it in a new house garage with white walls so the way we did it actually turned out pretty fast and easy
And yes it was a work out but my car is finally done feels and drives great. POWERFLEX is da sheeznet!!!!sigpicComment
