Rear weld on adjustable project
  • vtman05
    • 86
    About to put in the IE rear adjustable rear camber and toe stuff and was doing a refresh of the bushings while I was at it. What else should I plan on changing out while I am down there?
  • Gooch
    • Dec 2006
    • 1674
    Stainless steel brake lines and subframe/differential/trailing arm bushings is about all you need to do in the rear. Maybe rear shock mounts if they haven't already been replaced.
    '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
    '87 535i - Vacuum brake conversion [SOLD]
    '93 525iT - 5-speed swap - 320k and counting
    '09 328xi - 6-speed
    • Shappa
      • Jan 2008
      • 49
      cool
      I just put mine back in the car, But got to rebuild the axles and change a wheel bearing, which i just noticed after i put the subframe back in.
