Rear spring perch busted!!!
  • sl0ride
    • 154
    So i started working on my project today and i ran into a major problem. The rear left upper spring perch is demolished. Seems MD rust and crappy roads got the best of the perch and its torn almost the whole way around. I have a welder but this i can already see being a PITA. Anyone ever seen anything like this before?
    Tomorrow im going to level off the body and take some measurements to see if the rear body subframe is bent, i hope not because this body is heading to the JY if so. :(
    outside
    looking from inside
    what it should look like outside
    what it should look like inside
  • mikeedler
    • 6707
    go ahead and junk it.
    the e30 tourings have a bad problem of doing that over here. I have seen atleast 3-- but never a 2 or 4 door do that.
    • sl0ride
      • 154
      Man i really dont wana let this car go to the dump, at least i only spent ~700 on it. I guess ill part it :(
      • Asbradley21
        • Jun 2008
        • 1938
        Well, thats ONE way of lowering it. That sucks...
        S54B32 swap in progress. Status: Getting There
        • e30trooper
          • 11576
          im happy i live where cars dont rust!
          • KillaCam
            • 2103
            <3 California
            Originally posted by E30_(1st Musk)_
            HONDA IS WHERE EVERY TREND DIES! .
            24v swap Oil Pan..F/S
              That would be a real bear to repair. I suspect that the odds are that there is significant rust damage elsewhere, which would mean that this shell is junk yard fodder. Find another shell in better condition and make one good car out of two.
              • sl0ride
                • 154
                I talked with Yan a bit and i think what i will do is take off the subframes, inspect and build them up with the camber/toe tabs, re-enforcments, and poly bushings. Then decide if i will deal with this frame or source a new one. I think i will be leaning towards parting it and replacing the body.
                Anyone need good bronzit doors, hood, trunk :(
                Anyone have a straight clean body thats a roller or blown engine? :(
