Best place to buy wheel bearings and rear hubs?
    So my car is making a whining noise and i think its the wheel bearing. Where is the best place to buy a wheel bearing and also a rear hub since one of my hub has a stripped thread.
    Try to get a metric tap, and run it through the hub. I had a hub that ate up wheel bolts, and it cleared that up perfectly. Blunt has good deals on parts. Expect to pay around $130 per front wheel bearing from most vendors. I put FAG bearings on mike, but NTN and Timken are also brands I would put on my car.
    '89 325i track sloot
    '01 530i daily
    -Enginerd
      This is just rear bearings. Will I have to take the hub to the machine shop to get it pressed in?
        Oh, rears are $30-$50 each, depending where you get them.
        a nice DIY article: http://www.unofficialbmw.com/e30/sus...eplacement.pdf
        '01 530i daily
        -Enginerd
          To change a rear wheel bearing, you'll need a press or the Sir Tools B90 kit. While you can get a new rear hub, one from a salvage yard will likely be cheaper.
            Also do u think my brakes can be causing this whining noise? I mean my brakes haven't been change in a while and I think there warped. I already bought rotors and pads but I plan to do everything all at once. Because my dad told me that if a wheel bearing is bad the wheel well shake once its lifted. I lifted the car this morning and the wheel doesnt shake. Also another problem I have with my E30 is when I brake very hard the front passenger clicks what do u guys think the problem is?
              Fuck i dont think I have the right tools to do this wheel bearing....ahh fuck i think Ima have to take it to the shop
                Take the caliper off the rotor and spin the wheel. If it's the wheel bearing, you'll still hear it. When you are in a turn, does the noise get louder? That's another indicator that one side has a bad wheel bearing.
                Lots of things could make a click under hard braking. if all your balljoints are in good shape, first make sure your caliper bolts are tight, along with any suspension mounting bolts.
                '01 530i daily
                -Enginerd
                  I checked the suspension bolts, tie rods still look good,I thought that was the issue. And its just a constant humming noise. Corners the noise stays the same. It irrtates me that I dont know the exact problem and with my luck i'll probably spend the money on fixing the wrong part. I have no job so money is really hard to come by just last night I jacked up the car to fix my lip and found out my oil pan is leaking, I might have a leak in the radiator fluid. And today one of the lug studs were stripped.
                    I know this is an old thread but autozone sells bearings for cheap. They are boxed as Timkin but I believe they are made by FAG. I think they are $80 each (front) which can save you $50 or more.
