Do I have a brake problem?
  • CoClimber
    • Oct 2009
    • 80
    I've never driven an E30 before so I don't know what is normal. My '87 325is brakes feel weak to me. I have to press down fairly hard to stop quick, much harder than my 2004 Honda CRV, as a point of reference. The car has drilled and slotted rotors and stainless lines. Pads are good on all corners. I pumped new fluid to all corners and did a fair job bleeding the system. It doesn't get better if I pump the brakes so it doesn't feel like a need to bleed issue.
    When I was troubleshooting an engine issue I removed the vacuum hose from the master cylinder and there was a lot of vaccum stored there. Power brakes are one place I don't have a lot of experience.
    Any thoughts?
    sigpic'87 325is, S50, Lightened Flywheel, Ground Control suspension, Strut Tower Braces, Roll Bar, Five point Harness, lots of little go fast things.
    The effectiveness of the brakes is a strong function of what pads are fitted. in general, low dust pads will noticeably decrease braking performance. And having cross-drilled rotors doesn't help as the holes reduce the area swept by the pads. If you don't know what pads are on the car, or if they are a low dust type, replace them with OE equivalent or a High Performance Street pad
    • CoClimber
      • Oct 2009
      • 80
      Any suggestion for a relatively inexpensive street/autocross pad?
        Axxis ULT pads are probably about the cheapest HPS type pad. Though more expensive, if you don't mind some noise in street driving Hawk HP+ pads will work really well in AutoX events. For a sampling of pads see http://www.zeckhausen.com/BMW/E30.htm
