draining all brake fluid
  • Goya20
    • 325
    Taking all the fluid out the the car and replacing it will new will it build more pressure in the brake pedal? planning of doing that today. any suggestions i changed my calipers and master cylinder and it has some sink at the bottom of the pedal.
  • evil_twin
    • Nov 2007
    • 2965
    It will if you have air in the lines. You should replace your brake fluid every 2years I believe, but not many people do anyways. Flushing your fluid gets the moisture out of the brake system.
    Paypal: vdang5@gmail.com
    Delta Auto Care
    2875-C Towerview Road
    Herndon, VA
    703.435.1375
    My Feedback Thread: Evil_Twin
    • SkinnyVT
      • Nov 2008
      • 391
      You have air in your lines, did you not bleed your brakes when you changed calipers and MC? Just to be clear you flush the old fluid out with the new fluid, there is no draining of the system.
      '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
        • 37829
        Easiest way it to open up all 4 bleeder screws, keep filling with new fluid, close bleeder screws when fluid draining becomes clean.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • Mike325
          • Mar 2006
          • 3685
          Did you bench bleed your new master?
          Originally posted by Kershaw
          • Goya20
            • 325
            the mechanic jsut put it in and then we did the 2 man bleeding process. he said that will bleed the mc but i dnt believe him
            • evil_twin
              • Nov 2007
              • 2965
              You don't have to bench bleed the master cylinder if you bleed the entire system. Bench bleeding will help get the air bubbles out quicker since you're priming the master cylinder, but you're doing a complete flush anyways.
              Why take your car to a mechanic and have him do the work if you're not going to believe him? If anything happens, say your pedal goes to the floor because there is still air bubbles in it, it is his name that is on the ticket, his shop and he will be liable.
              Delta Auto Care
              Herndon, VA
              703.435.1375
              • flyboyx
                • 8371
                doesn't the abs get in the way of bleeding the brakes properly?
                Gigitty Gigitty!!!!
