Problem: I've lost nearly all pressure in my brake pedal. I did some searching here and it sounds like I've got a bad master cylinder. I'm ready to replace it, but I could use a little advice.
How it started: Went to flush/bleed brakes in my 86 325e. New-to-me car hasn't seen a brake flush in a decade probably. While pumping pedal with a rear bleeder valve opened, what I'm assuming to be trash in the lines clogged up the bleeder. Pumping the pedal fixed the first few little clogs, but eventually a big one showed up. I pumped the pedal a few times really hard and it felt like something popped. Suddenly it was really easy to pump the pedal, but there was no pressure.
Now, when I push the pedal with a bleeder open nothing comes out and I don't lose any fluid. I can apply a vacuum to a bleeder and it will pull fluid from the reservoir, but still no pressure.
My questions:
My questions:
- How should I proceed? I feel like I should blow out the lines with air, replace the rubber lines and rebuild the calipers. First car with ABS where I've messed with brakes though. Concerned about getting air in the ABS unit and not being able to get it out, damaging it and/or just screwing things up worse in general.
- ABS delete? Thoughts/opinions? Worth the effort? Seems simple enough. It's a dedicated Auto-X/track car, so I'm OK without it. Don't care about the weight savings by removing it, more interested in making the system simple and easy to work on.
