Brake Bleed Issues
  • vintage914racer
    • Jan 2010
    • 21
    One more unrelated question. Are the outlets on the MC interchangeable in regards to front back, or is one specifically for the front and the other specifically for the back fo the car. Basically, my question is do they push fluid proportionately, or is there some sort of internal valving in the MC.
    I think I might bypass the ABS tonight just to confirm that the pump is the issue. If once bypassed everything work fine I will know the ABS pump is the culprit.
    • 84E30
      • 456
      Guys i need your input.. I was driving home from work yesterday n my car is dropped
      i hit a dip n hit the bottom of my car came to a red light.. No brakes.. Dead Pedal all the way to the floor.. Pulled ova checked no brake fuild .. Everything had leaked out .. I think i may have busted a brake line or something? Any Ideas?
      Check out my Insurance Thread
      http://www.r3vlimited.com/board/showthread.php?t=164190
      • vintage914racer
        • Jan 2010
        • 21
        I'd put brake fluid in your system and then look for a leak. Or you can avoid this and simply inspect your hardlines under the car and look for damage.
        • 84E30
          • 456
          Thats what i'm doing this weekend.. Gonna take it to my buddy's shop n put it on the lift... Dont wanna play guessing games n start changing a bunch of parts...
          • vintage914racer
            • Jan 2010
            • 21
            Update:
            I did an ABS bypass to try to further diagnose my issue tonight. After doing so I am not getting fluid to both front calipers. Unfortunately I am still not getting any fluid to the rear calipers.
            Could a faulty MC prevent fluid from getting to the rear calipers? It seems unlikely, but as of now I'm grabbing for straws. Last night I was able to blow compressed air from through the hard lines leading to the rear so it can't be an obstruction.
