ive been experiencing brake problems. when i bought my car brakes were good, i change the pads and after a while it started acting up..then i had no brakes, i changed the master cylinder and they started working again, but the pedal feels soft...the issue is when i brake hard, the pedal feels weird as if the pads grip the rotor and then it slides and grabs it again. how i would describe it is that the brakes skip....and theres a noise skipping clunking noise when i brake hard....it happens even at really slow speeds and the pedal goes almost to the floor, but if i pump it it brakes a little better.
could it be the booster?
could it be a vacum leak on the booster?
is there a way to check the vacuum preasure?
just looking for stuff to check before going to the major things....
i know the rotors are almost gone, my mechanic resurfaced the front rotors
anything i should check?
