Rear wheel ABS
  • Strelok
    • Jan 2010
    • 280
    Rear wheel ABS
    Does a 4/87 325i have rear ABS? I got under the car and could not find any trace of sensor wires... Where should they be located?
    Thanks
  • Fidhle007
    I can fly, motherfucker
    • Oct 2005
    • 7209
    Yes.
    '89 325is S50 Track Montser
    '04 X5 Daily/Tow Vehicle
    http://www.avarestoration.com
    http://www.myspace.com/brendanfiddle
    Click here if you want to be my zombie slave...
    http://www.youtube.com/user/Fidhle007
    • FredK
      • 14761
      The sensor wires are in the same position as other E30s. The sensor exits from the rear of the car, right above the subframe, through a rubber grommet, on both sides. It then snakes to the trailing arm, and fits into a bore on the front side of the rear trailing arm.
