Another subframe bushing bolt thread
  • psyber_0ptix
    • 904
    But I was able to get mine out. My sleeved cracked and i used the FredK method with great success.
    Are the subframe bolts normally bent? both sides are quite tweaked and wasn't sure if it were time to replace or to pop them back in. If they are bent from factory, is there some index to them to get them in the proper orientation?
    Originally posted by FredK
    However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
    My year in Germany
    Feedback
  • FredK
    • 14763
    The subframe bolts are straight bolts. It'd take quite a bit to bend a 14mm piece of steel! Any pics of the bolts?
    • Charley
      • 396
      They are not supposed to be bent at all... time for a new set of bolts
      BTW post a pic of your bolts
      Charley
      edit: 1min...
      • psyber_0ptix
        • 904
        new bolts ordered, thanks guys
        My year in Germany
        Feedback
        • e304me
          • Feb 2006
          • 1374
          holy shit...
          • Charley
            • 396
            wow just wow
            Charley
            • Fidhle007
              I can fly, motherfucker
              • Oct 2005
              • 7209
              Stop jumping your car!
              '89 325is S50 Track Montser
              '04 X5 Daily/Tow Vehicle
              http://www.avarestoration.com
              http://www.myspace.com/brendanfiddle
              Click here if you want to be my zombie slave...
              http://www.youtube.com/user/Fidhle007
              • e30loverSC
                • 575
                I dont wanna know how to bend subframe bolts. 14mm of steel
                • psyber_0ptix
                  • 904
                  I've driven the car at most 100 feet. I picked it up from the previous owner and have slowly been fixing it. Needed to replace the brake hardline that spans the entire length of the underside. Doing a 5-lug conversion and removed the subframe for camber/toe mod, and found this.
                  the bolts are fairly inexpensive, but those washers are way over priced.
                  maybe I should start a build thread..
                  My year in Germany
                  Feedback
                  • hellakush
                    • 254
                    i'm gonna take a wild guess and say the that the po didn't have those bolts tightened at one point before he dropped it down and took it for a test drive.
                    I'd rather bag your mom than my car :D
                      Bad subframe bushings can result in bent bolts...
