Difference between front 318i/325i brakes?
  • bumster22
    • 40
    First post. Yes, I did the search. But, can't find the answer.
    I just bought '85 318i with 220k mi. for daily driving. I would like to upgrade the front brake to 325i vented unit.
    For those that have taken this path before. Please share your wisdom.
    What do I need? Would be nice if I can use some brake parts from my 318i for the conversion. But, I don't know the difference between 318i/325i brake. Other than one is vented:(
    Thank you in advance for your help.
    Bumster
    Fast lookin' Slow movin'
  • calypso
    • Sep 2004
    • 62
    My 318i has ventilated dics on the front.
    • bumster22
      • 40
      '90-91 318i is vented
      Calypso.
      I do know that later 318i came with 325i brakes. My is solid disc.
      I was hoping that the dia. of the disc is the same. What I'm not sure of is the thickness of vented disc might not work with my 318i caliper.
      Thanks,
      • Rob
        • 8166
        I'm think you can bolt later 325i calipers and vented rotors onto the early (small) strut housings. If not, its not a big or expensive proposal to upgrade the entire strut assembly, which will give you the bigger brakes as well as open more avenue for suspension choices.
        BEERTECH
        • boom-monkey
          • 1104
          I've got the front calipers as well as the rear trailing arms from a 325 so you could also swap to rear disks. PM me if you'd like to buy these off me. Peace.
          • rs4pro3
            • 5808
            You need, 325i/e rotors and calipers. They bolt right up no modification required. :D
            85 325e 2.7 ITB'd stroker
            • BimmerToad
              • Sep 2004
              • 1537
              I have a set of complete front suspension assemblies w/ brakes if you're interested.
              San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
              • bumster22
                • 40
                Thank you for all your inputs.
                Gentlemen,
                Thank you for all your inputs. I might just drive it the way it is.
                The reason why I want to upgrade the brakes and suspension. I got an extra M50 w/ 117k mi. that taken my garage space.
                Thanks again,
                Bumster
