Axle and general rear driveline/chassis knowledge needed ITT
  • sleepswithe30s
    • Oct 2007
    • 82
    Hi, if this has been covered I did do a brief search but didn't know what keywords would work best and came up empty handed.
    I am planning on building a 2.7i this summer with the possibility of forced induction in the semi near future (over the fall/winter). The motor will not be permanent and will be my fathers if/when I have the money and time to swap an s54.
    I think with that setup I should be looking at about 220-250 horsepower (afterforced induction and hopefully at the wheels) fairly safely, which should move this car very well. Anyway I was underneath the car last night spraying the undercarriage with oil (corrosion prevention) and I thought that the axles look very feeble in this car.
    So my question to the forum is where I can find stronger axles for this car? Also subframe and control arm re-enforcement seems like it may be a good idea to start looking at.
    In this thread I figured would be a good idea to compile what we know of the rear end of the car (mechanically) and possibly tow/sticky this thread in another forum if there is enough knowledge in this thread to justify it. ALL information on the subject is welcome :).
  • Dirtsquirt
    • Nov 2004
    • 686
    You don't need stronger axles until you've eclipsed 500whp...
    Your stock units will do just fine if they are in good shape.
    • Lurker27
      • 821
      You can break axles if you spin and hook, but its more a driving style issue than a parts weakness one.
      You'd need to do something extreme like full MZ3 or E28 rear for beefier axles
      '89 335is +turbo
