Brakes brakes brakes
  • ipunchfish
    • Oct 2009
    • 106
    Preamble: removed rotor, caliper to fix dust shield. Put them back on and felt like there was air in the system.
    Problem: I checked the pressure and everything is fine but the brakes dont feel right. It doesn't really inspire confidence under heavy braking.
    Im going to run a couple more tests and come back with a better description of whats happening. At work right now.
    Did you disconnect the lines to the calipers in the process? If so a flush/bleed of the brake is required.
