Doing a front refresh while I drop the car, I've found the Control Arms, Tie Rods, Brackets and Poly Bushings...purchasing through either Pelican or RME, do these kits come with the hardware as well or is this purchased separately? If purchased separately, where will I find the part #'s as nothing is listed?
Next question, since I'm removing the springs on the rear is it a good time to replace the rear trailing arm bushings, rear subframe and diff bushings or can this be done at a later time?
How important is adding the rear camber & toe correction kit?
Car is being built for weekend drives and HPDE's with hopes of Spec racing later on down the road.
