91 325i rear arms fit in 84 318i ?
  • QUKBMER
    • 8178
    Can you use 91 325i coupe rear arms and brakes in a 84 318i coupe. Will it fit? I know the question is why would i ,but i need to know. LOL. I need to know if the control arms are the same design at the subframe mounting and width and length.
    Thanks in advance.
  • accident
    • 7303
    as far as i know the rear trailing arm design didnt change until the E36
    Moral of this story?
    • cyberkaa
      • 1698
      According to realoem, the design changed in 9/1985. The diameters are different.
      http://realoem.com/bmw/showparts.do?...13&hg=33&fg=30
      -Kalim
      British Racing Green, IE Springs/Bilsteins, IE exhaust, IE SSK,
      Momo shift knob, Miller MAF conversion, K&N intake,
      Blackworks Aluminum Radiator, 5MT swapped,
      Ellipsoids w/DDM HIDs, OEM Recaro Sports, Momo Mod07 Wheel,
      Drilled+Slotted Rotors, Alpine HU/Amp/speakers, 12" enclosed sub
      • IronmanE30
        • Sep 2009
        • 2121
        Good news is that the rear sub-frame is the same part number so I think the trailing arms will bolt up to the sub-frame just fine. I think that is were you were going with this right?
        Cheers,
        Jim
        • Holland
          • Nov 2008
          • 7212
          I am 99.9 percent sure you won't have any issues.
          Originally posted by DEV0 E30
          • blueapplesoda
            • Dec 2005
            • 1904
            you'll be fine. only difference is bearing dia, but the flanges and all still bolt up. don't worrk about it
            • Jean
              • 18228
              Complete trailing arms swap jsut fine, no modifications needed.
              • StereoInstaller1
                GAS
                • 22679
                Originally posted by Jean
                Complete training arms swap jsut fine, no modifications needed.
                says the expert on swapping crap into an early chassis...
                Closing SOON!
                Thanks for 10 years of fun!
                • Jean
                  • 18228
                  lol.... drum brakes ftl
                  • QUKBMER
                    • 8178
                    Thank you very much.Bought the swap pieces to do a rear drum/ to disc conversion and we are also doing the front solid/ to vented rotor swap too. We are building a rally / time attack car.
                    • QUKBMER
                      • 8178
                      Cheers,
                      Jim
                      Thanks again for all the stuff jim !!!!!!!!!!!;)
                      • sacbmwdriver
                        • Aug 2009
                        • 422
                        what is the exact stuff you need to upgrade from drum to disks? i think im going to need to do this.
