Bentley is not clear on this and I'm reinstalling the trailing arms back onto the subframe after doing all the bushings and assorted stuff that needs to be done while the subframe's out. I'm mounting the trailing arms back onto the subframe and need to know if there's a torque spec on the four bolts? Also, are these bolts supposed to be tightened after the rest of the suspension is installed to correctly orient them? There's no damn way a torque wrench will fit up there after they're installed though!?
HELP!! with trailing arm install
I take it you didn't drop the subframe to replace all 6 bushings at once, it would then give you all the access you need to torque the trailing arm bolts and replace the rear upper brake lines ;)Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827 -
Actually yes, I've got the subframe and trailing arms laying on the ground as we speak. My questions are what are what is the torque spec and are they supposed to be tightened at ride height? But you can't get a torque wrench on those nuts once it's installed. How do I prevent the bushings from binding if tightened w/o weight of the car on them?Comment
Give me a few minutes, looking through e30 workshop manual...Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Ok page 774 section 33-7 says to tighten the trailing arms bolts with car in normal position.
Torque specs = can't find them hmmmLast edited by Jean; 08-22-2010, 01:10 PM.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Make them tight. Drive for a day. re check. I was told this by my friend Roland who works at a BMW dealer, that sometimes even their books don't give all torque specsComment
Let me revive this old thread.
I found a source that said the torque spec is 67 Nm with suspension loaded.
Suspension being loaded means the car is on the ground, doesn't it? How am I going to get under there and torque the bolts down with suspension loaded? Let alone using a torque wrench.90 E30 S50B30
http://www.fquick.com/roadhazard/Comment
You need to tighten them under load, otherwise they'll wear out quickly from binding. Plus, you'll need them somewhat loose before installing the whole subframe assembly anyway. Just get them snugged down enough so they can still move. I put the rear wheels up on ramps and held the bolt end with a wrench and tightened the nut end with a ratchet wrench. There's no way in hell you can get a torque wrench on them. A ratchet wrench will just baaaarrrely fit and then you can only tighten a couple clicks at a time. Just get them tight and you'll be fine.Comment
quick idea why not just jack up the the suspension on the corner you are working on, to ride height then torque away?sigpicComment
It's not the arms or springs that's an issue. Once you pop the subframe back into place it's too tight to get a torque wrench on the arm bolts/nuts. Guess I'll be doing my next set the way Trent described.Comment
