Hi all...
So i'm looking at replacing my RTAB because my rear toe is all messed up and it's killing the tires, but after doing some research, it seems like i'll have to take out the whole rear end to do it, so i'm looking at replacing the diff mount bushing as well.
So i'm looking into purchasing the AKG Rear Subframe and Diff Mount Bushing set...Poly 75D, but it says FOR RACE USE ONLY. What's with that? My car is a daily driver, but i definitely don't mind having a stiff suspension if that's what the difference in poly does.
Also was going to get the RTAB 75D in poly as well.
What do you guys think? Should i get the Acentric RTAB?
